Discuss Toilet Siphon diaphragm replacement? in the USA area at PlumbersForums.net
macka09
Hi guys. One of the in-laws has an issue with her toilet not flushing. I’ve had a very quick look and it seems the plastic diaphragm has split in the siphon. It’s an older siphon but luckily it does split in to 2 so I don’t have to replace the whole thing, but that’s only if one of you good chaps no whether a spare is available? I’ll attach a photo for reference. Normally I would swap the whole thing but that’s normally because it’s not a 2 piece siphon. Cheers guys
No need to replace whole siphon, replace washer only. Just need to dismantle which in this case is simple enough, have a look at washer, they do vary but replacements are available from good plumbers merchants. Most plumbers have a selection in their van.
Just get a piece of thick plastic or dpm and get the knife and scissors out
In a spot I use a rubble sack, can use a double thickness ie, cut 2, use old diaphragm for pattern.
Reply to Toilet Siphon diaphragm replacement? in the USA area at PlumbersForums.net
