Discuss toilet tank no water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
daku
hey guys
just moved into a new property and flushed the toilet for the 1st time and all was fine.
few hrs later tried to flush again and it wont happen. There water doesnt seem to be flowing in the tank. Filled up the tank manually using a jug and the toilet flushed fine.
so no water is reaching the tank?? any solutions
much appreciated. thanks
water from taps seem to be working fine.
Is there a valve underneath the toilet or is the inlet valve stuck? Is it a ball float or a little plastic thing?
Is there an isolator underneath or anything? Welcome to the forum
Suffering from a touch of the zeb's
Obviously that should read pipework ......dam you predictive text:)
hey guys,
not at the property at the moment, as far as im aware there is no ball pump in the tank. could the previous owners have turned water to the toilet off somehow? . will take picture once im there
cheers
Reply to toilet tank no water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey Guys I’ve noticed this weekend that my en-suite toilet pan water level is seeming to regress after an hour. Toilet flushes as normal and...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
