Discuss Toilet waste lower than soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We've just had a new toilet installed and the new toilet's waste pipe is lower than the cast iron soil pipe. My installer has used a flexi pipe to connect the toilet waste upwards to the soil pipe. Am I right to be concerned about the upwards connection, and the use of a flexi pipe? The cast iron soil pipe is about 1 inch higher than the toilet waste pipe. What might a good solution be?
Need to raise the toilet
That flexi isn’t acceptable either look at that sharp bend
Get the installer back
Thanks for your quick reply. When you say the flexi isn't acceptable, is that the silver clean water pipe?
And by raising the toilet would that mean putting it on a plinth?
Also, any thoughts on the use of the flexible pan connector? I've read a few things about them not being very good.
Yes too sharp of a bend (looks kinked) they tend to split when it’s done like that
Yes or could you raise the floor ?
There ok not the best tho but not installed like that
We could raise the floor a bit - how much to you think it would need?
I can't help thinking that we should have been advised to get a wall hung pan that could have been put at the correct level needed instead of messing with the floor level or a plinth!
So that the outlet is at the same height as the inlet
Thanks for your replies.
If we can't raise the floor and I don't want a plinth, should I ask for re-installation with a different toilet, say a wall hung one that can be put at the correct height?
Who bought the toilet ?
I bought that toilet, however I did send the link to the installer first to confirm it would work and the installed had viewed the bathroom and said it was ok to order.
New posts
Reply to Toilet waste lower than soil pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
