Discuss Toilet Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
leslie50
Why are there so many issues ,had to replace toilet, Grey waste going into wall is about 3inch higher then the toilet itself, did connect with flex waste but the angle of the waste pipe look all wrong , the grey waste pipe is easy to get to outside, my idea is to put a new grey waste through the wall at the right height, could make a little platform for the toilet ,but felt it would not look nice. Any Tips would be greatly accepted .
Les
Done two of these for the people we contract to just raised the toilet on wood and got some of that bendy edging stuff they put round windows screwed and put some mastic on it. Winner ;)
Hi Mikey, what wood do you put it on? And any idea what that bendy stuff is actually called? Thanks
I assume he just uses UPVC trim which you can buy from fleabay or from any window company. Comes in different thicknesses etc, I recently bought some to sort out the conservatory, cost about £8 for a 3 metre length.
Reply to Toilet Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
I'm a DIYer and have a problematic toilet setup to fix: The waste pipe was installed too high for waste to flow out from a standard toilet...
I’d like to replace the toilet in my house with a back to wall one. The plan is to build a panel on stud work to conceal the cistern and then use...
2K
I currently have a floor standing pan in a downstairs cloakroom. The waste is vertical about 10mm on the inside of a 2- brick external wall. As...
2K
Attached is a ground floor picture of the soil pipe in our home. There was originally a toilet which has now been permanently capped off and you...
1K
