Discuss Toilet water leak advice wanted in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I get a slight leak of water in the bowl. Any advice re the attached please. Thank you in advance
Siamp optima 49 will only twist one way have a look on the carriage for the stops and there should be an opening on one side twist while holding the bottom carriage that way
You will need a new washer prob bubbled
Look to be the washer. It seems it’s 2 1/4 inch. I can’t seem to find one online. Any ideas where in the uk I can obtain and what I should search for online? Thanks
Just get a whole new flush valve and just swap the top half eg the bit you remove I normally do
But here’s a link to the Washer
Reply to Toilet water leak advice wanted in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
