Discuss torque adjustable wrench, as a plumbing tool in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ted808
Hi guys, ever heard of one of these?
Does anybody use one?
I use a torque wrench every now and then but it's more like a socket set than that adjustable. I have two different types.
Why do you ask ?
I own 3 torque wrenches and ive never used one for plumbing work.
only usually need anything like that on flanges and then just do em up FT
Why do you ask ?
Fella I did a job for- architect, wanted me to use it on uponor fittings... just seemed bit ott!
That is odd. Never used one on plumbing before, not even commercial stuff. I know when something's tight enough without one, like most Engineers.
Last time I used one, it was to prove a point and settle a slight disagreement.
Reply to torque adjustable wrench, as a plumbing tool in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
