Discuss torque wrench for service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hellfire
anyone use a torque wrench when replacing the gasket on burner door after service or repair if so what Nm settings do you use
No but 6-7nm will do for most but each manufacturer has there own spec
Reply to torque wrench for service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Never seen that type of ratchet wrench before... https://www.youtube.com/shorts/G9BhDrQPKAU Could be useful, Amazon sell singles of large sizes... https://www.maxrpm.de/BGS-Line-Ratchet-Wrench-Set-6-pcs-BGS-8665?curr=GBP&opi=95576897
Hi, I'm trying replace a basin waste and I cannot get the chrome ring attaching it to the trap undone. It's not a nut so using a wrench with rag is just slipping. I've tried release spray but still no movement. Any suggestions? Cheers, Andy
Hi, I can’t get one cartridge to budge when trying to replace in a mixer tap. The hot side cartridge was tight but removed with wrench comfortably, but cold side is so tight Ive burred the nut on the cartridge. Any advice on how else to remove the cartridge without damaging the mixer tap is...
A
Hi guys I finished my gas course in September can anyone help me i need to do 2 install and services. Am living i ln leeds west yorkshire I do appreciated for any advices . MOD* Please use the forum PM Service to contact members! Thanks!
Ahmad marian
A
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
