Discuss tower zone valve in the Plumbing Zone area at PlumbersForums.net
W
willieplumb
Hi, this is my first post and would love some help.
I need to replace a Tower spring loaded motorised valve type
TOWER VALVE MV2-22C
I want to replace the complete head without having to drain down.
The valve is one of the older type with a grey plastic cover.
I have been told that the head on these valves can not be removed, I have also been told that they can be removed an replaced. Could someone please advise as I do not know which to do, try and replace head or drain down and replace the whole valve.
Would appreciate any advise,
Hi, when you say actuator is that the complete head , motor, micro switch, spring mechanism ect. which will leave the valve intact. If so I am getting conflicting reports. Some say on this old valve this is not removable and some say it is.
Thanks for your help.
Might I suggest you call the manufacturer as without eyes on it its nigh on impossible for us to be 100%
Reply to tower zone valve in the Plumbing Zone area at PlumbersForums.net
I have a CH circuit on a 2 way zone valve. It’s a long circuit with 15 rads on it but rather than shutting down the last 5 rads in the circuit...
Hi, first time plumber and poster here. I've installed two new zone valves and replicated the direction inwhich the original valves were...
Deleted member 120897
Afternoon Fellas If anyone has time to help with this snag it'd be much appreciated. We have a wet-floor system controlled by John Guest UH3 and...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
A bit of clarification - I have extended a 3 bedroom semi detached and at the time central heating pipes were going in I told the plumber could I...
