Discuss tower zone valve in the Plumbing Zone area at PlumbersForums.net
W
willieplumb
Hi, this is my first post and would love some help.
I need to replace a Tower spring loaded motorised valve type
TOWER VALVE MV2-22C
I want to replace the complete head without having to drain down.
The valve is one of the older type with a grey plastic cover.
I have been told that the head on these valves can not be removed, I have also been told that they can be removed an replaced. Could someone please advise as I do not know which to do, try and replace head or drain down and replace the whole valve.
Would appreciate any advise,
Hi, when you say actuator is that the complete head , motor, micro switch, spring mechanism ect. which will leave the valve intact. If so I am getting conflicting reports. Some say on this old valve this is not removable and some say it is.
Thanks for your help.
Might I suggest you call the manufacturer as without eyes on it its nigh on impossible for us to be 100%
Reply to tower zone valve in the Plumbing Zone area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
