Discuss Tracpipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Never not required, no sealant required does say in the instructions
As Shaun says never had to use sealant the pipe needs to be cut square to allow the fitting to form a perfect flange to seal the fitting, given a choice I prefer Gastite pipe and their fittings easier to use and the split ring is bigger . Kop
As Shaun says never had to use sealant the pipe needs to be cut square to allow the fitting to form a perfect flange to seal the fitting, given a choice I prefer Gastite pipe and their fittings . Kop
agree gastite much better no tape afterwards etc
I wrapem
gastite you dont have to tape at all
Agreed Gastite split collar locks onto the outer jacket as well as the pipe creating a seal on them both .
[automerge]1567543989[/automerge]
Whats the difference in the pipe?
Or is it just better fittings on the gastite
Pipe is much the same bud its the fittings that differ have a look on you tube . Kop
pipe dia are different eg 20, 25, 32 etc
as trac pipe is 15, 22, 28 etc
also fittings are different gastite you dont need to add tape and cheaper
trac you need to add tape after wards
Nice first post. I assume you're something to do with Tracpipe then?
If so, go steady please. You aren't allowed to plug your own products on here.
Dan
Dan
I'm not, I did the Tracpipe installers course on my Gas course 2 months ago, so its still fresh in my mind.
Still waiting for ACS pass results to go through before I can be Gas Safe registered.
Shaun sums up the options very well ( with which I agree). Irrespective of which product you use, a tightness test properly executed identifies problems before you leave site.
Reply to Tracpipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Does anyone know a good, not super expensive, leak detection company in the London area?
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
