Discuss Triton Aspirante 8.5kW pressure release device in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
The pressure release device in my Triton Aspirante shower has blown; unfortunately I can't work out how to access it to replace it
It is behind the outlet pipe and there's just not enough room to maneuver the outlet pipe around to get access.
Does anyone know how to replace it in this model?
yes that's right - two screws holding in the outlet pipe
unscrewing them allows it be move up and down a little, but not enough to get it out
rotating it around isn't possible because the pressure relief device itself gets in the way
Had a plumber round this morning - the answer here is that the bottom of the shower is a trim piece that can be removed to give access. Unfortunately this wasn't obvious because it had been siliconed all the way round (apparently wrong) and a bunch of limecale also made it a bit tricky
Reply to Triton Aspirante 8.5kW pressure release device in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
