Discuss TRV controlled radiators passing by in the Central Heating Forum area at PlumbersForums.net
Is it me or do others have the same. I have out of 23 rads in the house maybe 6 that pass by even when on the frost setting with the room temp at 10 degC. It is as if they need a small solid washer or similar inserted into the trv head to make it act a tad before it would alone. The rads do not get hot but are still warm when they should be totally off.
Doubt it, unless they haven't been fitted correctly but then you'd get an error if that was the case.
Bare in mind that even at frost setting it doesn't allow the system temp to drop below 5 degC.
There's probably crud stuck under or into the valve washer.
Depending on what brand of valves you have, you may be able to change the valve bonnet in the valve.
Some valves bonnets can be changed, with a valve specific tool, when the system is under pressure.
I would change the valves, if it is causing you some concern.
Should not be any crud as all new trvs
If you’ve got it balanced nicely, but want to turn a few off. You can do it at the lockshields- just count the number of turns to the nearest 1/8 and WRITE it down somewhere safe. Then you can put it back exactly the same when you want those rads on a bit.
It makes no difference which end is fully closed- there’ll be no flow through that rad.
That is a good one. If I write it down will guarantee is lost come the same evening!
Reply to TRV controlled radiators passing by in the Central Heating Forum area at PlumbersForums.net
