Discuss TRV valve body compatibility with Hive? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive.
I am looking for an adapter that will be able to convert my existing valve body to the Hive TRV. Looking at the Hive instructions if the Adapter guide fits over the screw thread then I should ask Hive for an M28 adapter, BUT from the diagrams I don't think the M28 adapter will give the right fit as my valve body has 25mm from the top of the valve screw to the push pin and the adapter looks quite compact.
Please see the attached photos of the valve body and a comparison with a Danfoss trv screw thread for comparison.
Your ideas would be welcome, ideally, I don't want to replace the valve bodies as I will need to do 8 of them.
Many thanks
Matt
Best to ask hive
Reply to TRV valve body compatibility with Hive? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
A
Hello I am a diyer, I am looking at fitting a hive thermostat to my boiler but can't see a wired diagram of where the wires of the hive go on the boiler that's the only part I am stuck on so if anyone could help would be much appreciated.
Deleted member 120897
Hi, I need to remove some radiators for redecorating and went to try and shut off the valves either side of my rad. I have TRV on one side and on the other side I noticed a blank top with no valve or peg sticking out that allows you to turn on or off (see pictures). I checked the other rads in...
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and replaced it with new components from Nu-Heat but the valve is not working properly. The valve replacement seems very simple with 4 main components and some...
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing radiator valve setup is: The current valve has a 3/4" thread going to the radiator. I can't quite work out what's on the radiator side, but the...
2K
Daley power
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
