Discuss TRv's and plinth heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Markym4rk
I have 2 radiators in my kitchen which both have TRV's fitted.
I need to replace 1 of the radiators and purchased a hydronic plinth heater which will activate when ever the central heating reaches 40deg.
My question is how do i control the heat output from the heater as there is no obvious place to fit the TRV.
Can i pipe the heater in series with the 1 remaining radiator so the TRV on the radiator would control the flow of heating water to the radiator and heater?
Thank You
you need a thermostat control in your room to turn your plinth heater on and off. Have a word with an electrician.
Don't run in series - you might as well remove the other radiator as do this.
You might get away with fitting an inline TRV with remote sensor connected by a long capillary so you can put the sensor elsewhere in the room.
Reply to TRv's and plinth heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
