Discuss TRV's & Boiler+ (Boiler Plus) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jerry
Evening All!
I am having a thick moment. Again.
What does boiler+ say about installing TRVs when swapping a boiler?
I have heard some say that you (always) need to fit TRVs when swapping a boiler. Others say that you dont now don't need TRVs with the uprated Boiler+ controls.
Any thoughts?
J
If your only changing the boiler then trvs are only a recomendation. If changing the boiler and radiators then they are required.
still only recommended even when your doing a new system
Evening All!
Any thoughts?
J
My understanding is boiler plus relates to the boiler only, whereas TRVs fall under domestic building compliance guide.
Reply to TRV's & Boiler+ (Boiler Plus) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
