Discuss TRVs - their Purpose and Function in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Best
Subscribed
Sorry if this appears to be a simplistic question, but not as easy to answer perhaps as we think.
It is to settle an argument.
As the title says, - what are TRVs supposed to do in all respects and what way do they operate?
By sensing room temperature they open or close to keep the room at the temp set. They generally operate like a conventional ball valve in so far as they let less water through the closer they get to set point.
They generally use a wax capsule which expands. The winding you do moves it closer/farther.
Well that is basically how I would describe TRVs, but I have been told I am wrong, so you are also both wrong if we believe what I am being told.
Apparently they are -
A Proportional control adjusting the flow through a radiator so it is producing exact amount of heat.
They are designed (allegedly) to be full open when room temperature is one degree below set temperature and closed when room is one degree above.
They operate as balancing valves and shouldn’t operate as on/off valves.
So what do you reckon?
I did say it wasn’t as easy as it appears.
I'd say that was put together by someone without experience of the real world. Of course they are proportional - so is the ball valve description of mine.
Show me any space that performs as designed on the drawing board and I'll share my non existent fortune :rolleyes:
Out of idle curiosity, what else does one call the reduction of flow to zero if it's not 'off'? ;)
Academic or sales BS :D
Explain that to the customer??? Think I’ll stick to what I said above.
Depends on the valve the new imi valve have flow setters in the trvs so I'm guessing someone's been on a course ?
Reply to TRVs - their Purpose and Function in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
