Discuss Turning off the boiler - anything I should keep in mind? in the USA area at PlumbersForums.net
Having all the radiators removed for a full house replaster. House is unoccupied at the moment.
There is a Vaillant eco tec 28 boiler with a Boss RF Thermostat.
1) The Thermostat is just stuck to the wall - so can I just remove it - or do I need to deactivate it first?
2) Once I switch off the boiler - will it be better to remove all the radiators and drain the system? Or keep the boiler on and then drain the system?
What would procedure be for refilling the system?
Turn it off at the fused spur and remove the fuse then drain down
Reply to Turning off the boiler - anything I should keep in mind? in the USA area at PlumbersForums.net
Hi wonder if anyone can help. Had no issues last year. Have Valiant ecoTEC plus and Drayton thermostat. I have tended to leave thernostat and...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
On my Valliant eco tec boiler the pressure guage is on red when cold . I drain a radiator to correct to pressure and it works fine and stays in...
Oliver1234
O
I have a Glowworm Ultimate 35C boiler. It shuts off at its max temp of 60C when heating radiators and the pump carries on running pumping heat...
The system is open vented with a Glowworm boiler. It has an LCD controller on the wall - see pic. I just want to remove one radiator for cleaning...
