Discuss U codes on Worcester boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Morning all. I have a Worcester greenstar which keeps giving U codes by counting up to 9. Cannot see these codes in the manual. Any ideas? Cheers
Never seen that one before. Is it doing anything else? Any noises/low pressure?
Basically overheats. Turns on, temp shoots up to 90 and starts counting up with the U codes. Either sludge or pump failing me thinks
Its basically an overheat. They represent the temperature over 90 or 100 degrees I think.
Reply to U codes on Worcester boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
