Discuss UFH Pump - Always on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I think the nest has an underfloor heating setting? It certainly has a "radiator" option. I think the trouble here is the pump has a permanent live, likely from a crossed wire with the grey on the 2 port valve... assuming there is one!
Does the pump run even when the boilers off?
Nest works with both electric and wet underfloor heating systems. The latter must be properly designed and well balanced to deliver a consistent and even heat pattern to give Nest a chance to work effectively.
The normal issue ( problem) is that the Nest Heatlinks for multiple zones are placed too close together and too close to “significant” metallic objects - multiple copper pipes or hot water storage tanks. Heatlinks should be spaced at least 300mm apart, preferably a lot more. To be fair this is an issue ( signal interference) with the Honeywell wireless systems too
Hi Jones, the pump shows the green light always, and makes a very low sound, which is mirrored through the pipes. So I’m assuming it’s doing something... even when the boiler isn’t being called.
Reply to UFH Pump - Always on? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
