Discuss Unable to remove lever on Methven sink mixer in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi All,
I have a Methven mixer that is leaking around the base so I bought a Fixit-It repair kit.
It does not have a red/blue cover for access to the grub screw at the front but a little indent at the back.
I have tried using a 2.5mm allen key to remove the lever but cannot find the screw .
What am I doing wrong ?
It could well be a 2mm Allen or a slotted grubscrew.
Try taking a photo on your phone , which you can then zoom in - might need to provide a light source too.
Thanks for the reply. Used a mirror and torch and I can see the grub screw that is accessible at a 45 degree angle but for the life a me I can't get the allen key in when I use a 2/2.5mm key. What a stupid design.
Hiya, we're having a similar issue. Did you manage to do it and if so, how?
Thank you!
Hi Chantal, Got a plumber to come round and he could not access the grub screw either. It is a poor design for serviceability.
In the end I just got him to replace the mixer. Will not be using Methven in the future nor will I be recommending the product.
Reply to Unable to remove lever on Methven sink mixer in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage! I have removed the grub screw,but cannot lift off the...
2K
I have a twin control, 2 way diverter and temperature knobs, Noken NK Porcelanosa mixer with really stiff controls. I'm trying to identify...
2K
I am trying to replace the cartridge for a waterfall tap (mixer mono) for the bathroom sink, I have run into a problem whereby I cannot remove the...
B
Need to remove the spout on a Franke Olympus tap. I have removed the hot/cold previously with an allen key and the spout kit has a 2.5mm allen key...
Bob Hope
B
I'm probably missing something obvious, would welcome any suggestions on how I get access to the washers. We have a matching bathroom suite and...
Deleted member 120897
