Discuss Underfloor heating manifold? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Elverstown
I would have thought on the brass two port header going out to the floor
Yes but when both Z valves there will be no flow to measure anyway, have you discovered who made the manifold.
It does look like a fool of a thing, if both zone valves close looks like pump will be running against a closed end, am I right in assuming this, perhaps the control module shuts the pump off when all the valves are satisfied, if it is Pulsar they are not in business
Still dont know what manifold, when I replaced the boiler, their was a single time clock feeding rads roomstat to rads 2 port valve and boiler, open flow to cyl and u/f. with new boiler I have added 3 channel time clock, cyl stat and cyl 2 port valve and volt free switching to boiler. my concern is overheating the floor/if I attach the probe and temp valve closes then I am dependent on the boiler bypass (Vaillant 624)
Looks like the F/R loop back to the boiler is kept at the right temp by the TV and the UFH pump takes water as it needs to, crude
Crude is being polite, about a foot behind a 400mm kitchen cabinet, no need for all the electronics, just a thermostat to the pump would have done. cowboy renovators of the early naughtys.
Reply to Underfloor heating manifold? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
