Discuss Underground oil tank feed problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The boiler works fine if I connect the hoses up to a remote tank of diesel. I am assuming that a filter is blocked somewhere but there is nothing between the boiler and the tank. On the top of the tank I can see the return pipe, the supply on/off lever and another pipe which I assume to be the inlet pipe. There is also a plastic bung in the centre which can be removed. I have pictures. My question is whether anyone knows if there might be a strainer or filter within the tank and if anyone has ever removed any of these components to clean them?
Reply to Underground oil tank feed problem in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
J
Moved into an old house that has a vented gravity fed system (cold water tank and feed + expansion tank in the attic). I need to replace all...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
A
My oil boiler is 2009 vintage. Just been serviced. Had a new tank fitted by approved fitter. I notice that the bottom of the tank is roughly on...
Been in property about 10 years and the valve on the (round/bunded) Balmoral tank has always been in pretty rusty state. Tank is 5,000 litres but...
