Discuss Underground pipe connection advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wtjfree
Hi all,
I am currently doing a diy project to creat a downstairs wc.
I have laid a 3m underground pipe(110mm) through the kitchen and connected to main waste pipe.
My concern is that can I drill few 40mm holes on the “leveled” waste pipe to connect sink and dishwasher etc.? Is there any other option?
Any comments would be highly appreciated
You can either 1) cut the pipe you've laid (I presume there's a fall on it) and put tees on it, called 4 inch x inch and a half or inch and a quarter boss branches or 2) you can buy 4 inch x inch and a half or inch and a quarter strap on bosses which will involve drilling the correct size hole in the 4 inch pipe you've laid carefully with a the right size holesaw bit. In both cases use plenty of solvent glue and give it 12-24 hours to set before testing it.
Reply to Underground pipe connection advice needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
