Discuss Undersink plumbing washing machine etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We've been having issues with our washing machine recently where it is filling up in the drum overnight with clean water.
I just went to look underthe sink to check (actually don't know what I was checking for!) anyway I knocked a small blue lever about 1/4 turn and all this water came gushing out.
I have now switched this tap back to off position
Should there be something at the bottom of this pipe??
Also washing machine is all plumbed in correctly further along the pipework close to back of machine, so does anyone know why my machine drum is filling up?
Hello Branchy,
That appears to be a cold fill for either your washing machine or maybe a dishwasher. What tap is your washing machine plumbed into? Take a photo futher back so we can see a bit more to help us with what maybe the issue. Also anything changed/renewed recently, eg a new tap or shower etc?
Hello Branchy,
The copper pipework that heads out the left side behind has more taps on where the washer and dishwasher both plumb in to.
Have checked and there's no loose pipework that could go on to this lever under the sink, first time I've properly looked so unsure if there's ever been anything on there.
Yes we've had a new shower fitted about 3 weeks ago..
Ok, so it must be an old feed then. Easily changed to an elbow given the use of speed fit fittings. Do you have a combi boiler? Did this problem start about 3 weeks ago? Could be cold forcing hot out of the way on the shower if it’s a mixer. Are you able to isolate the shower?
Are you able to tell me what sort of fitting I am looking for?
No this problem with the machine only started about 4 or 5 days ago
Thank you :) will sort out fitting that on
Do you think the problem with the machine is the machine or plumbing related
It could be either, that’s why I was asking if anything has changed or been renewed,like your shower. What type of shower is it? Can you isolate it?
It's a electric pressure shower. But it was a replacement for the already existing unit not a new installation. No idea how to isolate it haha
I presume it’s a power shower? This could be the issue,but would need to isolate to confirm. There should be isolation valves on the feeds to it.
Internal electric valve of washing machine could be faulty.
Seen that happening and machine filling up to top drawer and flooding out
There will be a little blue lever on the valve that is connected to the washing machine feed pipe. Close this overnight.
If your machine still has water in tomorrow then it's getting there through the waste and your waste plumbing is at fault.
If no water then the washing machine is at fault and likely needs a new water inlet valve.
If closing this works and point to washing machine fault, are the water inlet valves cheap and simple to replace, or would a new machine be best
Inlet valves are quite cheap, mine was £20 , it was pretty simple to replace - the whole job took less than an hour.
Depends on machine layout of course as I believe sometimes other parts have to be removed to gain access.
So to answer your question, it depends on age/general state of/value of your machine - but if all else is ok I would definitely repair.
If I remove the blue handle will I not just flood the kitchen as there was loads of water gushing out when I knocked it open?
If it’s in the off position, the handle is held in by a screw, unscrew this handle - less likely to turn on after that as it’s a metal spindle, usually only openable by spanner/grips etc.
Edit: Brass Cap 3/4"
Branch don’t get fixated on the pipework under the sink, do JC’s test to find the problem.
The pipework almost certainly has nothing to do with your issue; yes it all wants tidying up but that can be done later.
That's OK my main thing I need to sort is our washer, just worried now I might knock that other thing open haha. Have turned valve off to washer for today to see what goes on
As Ben-gee says, don't worry about your pipes under the sink, you knocked the blue handle and opened the 'tap' under the sink, don't knock it again, or do as above, i.e. remove it or take the handle off.
It is only there because the previous tenant/owner probably had a water dispensing fridge plumbed in, as long as it's not leaking it's irrelevant now.
Hi there
The problem you have is with your cold water inlet valve nothing to do with the pipe work.
The other with the isolation valve it looks to me that’s a 15mm 1/2 inch. Just get a BLANK NUT ½ X (51939) . This is a Screwfix part no.
Reply to Undersink plumbing washing machine etc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
This is a picture of my sons sink plumbing. The yellow arrow goes to the dishwasher and the red arrow goes to the washing machine. There is a...
Need to plumb in a new washing machine. The room has a sink and toilet one one side, and at the other end of the room, enough space for washing...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
Hello all, The kitchen sink in the property we are renting drains really slowly, and I was hoping to remedy or alleviate this with some educated...
