Discuss Unknown pipe after pump in the Central Heating Forum area at PlumbersForums.net
Hello does anyone know what this pipe is which diverges from the main pipe after the central heating pump. It seems to connect to the return pipe from the cylinder, so I guess it isn't a bypass?
Bypass not needed with a 3 port so you can close the valve fully
Reply to Unknown pipe after pump in the Central Heating Forum area at PlumbersForums.net
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
