Discuss Unvented cylinder maintenance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Does anyone get involved in maintenance of UV cylinders?
Been sent this picture asking if I can have a look as it's leaking
Would you bother repairing a it looks to have multiple leaks and generally be in a bad state
Thanks all. I will take a look and quote for to replace
Think its possible that the time for good maintenance is passed n time to replace ,
I went to have a look and it worse than the pics
9 years old and leaking from every hole:rolleyes:
Reply to Unvented cylinder maintenance in the Plumbing Jobs | The Job-board area at PlumbersForums.net
losing pressure
L
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element...
Peter M
