Discuss Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Tbh i'd go off local recommendations from people who have actually used someone.
Agreed. Alternatively, if that doesn't work, try the cylinder manufacturer's website. They'll usually list several 'approved installers' for your area. They'll have done the manufacturer's product-specific training and you may get a longer warranty if you use them.
Is that INC VAT and you supplying all the materials and sourcing them? Or they sorting materials too.
Thats purely the labour content.inc vat. I have the cylinder, they say to supply pipe and fittings. Plus 1 zone valve.
Change y to s plan.
Move mag filter, as apparently its only on heating return and doing nowt for the boiler.
Raise f+e tank in loft.
Fit cylinder in loft on platform ive built.
Pipework to be run up new airing cupboard wall. Its a blank canvas in my book...
Am i so out of touch with life in 23!!?
I would say 3 days with lagging and the discharge pipework that runs externally u less you have a soil vent up there
Also I would recommended sealing the system as the cylinder is in the loft high chance of pumping over
3 days for 1 man?
NO, no soil vent, but there are easy options for discharge i would think...
Yes or 4 if it’s a pain discharge has to be copper or high temp plastic and if over x m it has to be 28mm it can’t be overflow tube
I would as your having the cylinder in the loft better heat up times customers report and not open to atmosphere so better water quality if flushed
Why high chance of what pumping over??
You haven’t much head from the top of the cylinder coil and bottom of the f and e tank at present you have around 2.4m ish with a cylinder in the loft maybe 1-1.5 m max
Yes you want a min of 2m above the coil of the cylinder to the bottom of the f and e tank
Think of your current height and coil height bet that’s over 2m
Cws tank to current vented cylinder....yes.
Why does the feed and expansion for the boiler need to be a mimimum 2m??
To have a high resistance so when hot water only is on it doesn’t pump over
You are assuming the feed and vent are connected either side of the boiler? I'd have the feed and vent both on the suction side of the pump on a low head system, no pumping over and only consideration is enough head to prevent cavitation.
Like this. Both cold feed and vent on the flow pipe off the boiler.
Reply to Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
H
Sizing an indirect H/W cylinder. What size of H/W cylinder would I need for a property with 9 bathrooms?
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
