Discuss Upgrade gas supply line from galvenised steel to copper? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
SoniaMarie
I'm wondering if a failed gas line test indicates a gas leak. If so, is it a requirement to upgrade gas supply line from galvanised steel to copper? Would you replace all gas pipes? What would you be looking at in terms of cost in Victoria Australia?
I would say yes you have a leak if it’s failed a pressure testing and depending on how it’s run might be cheaper to replace than to find the leak
@oz-plumber
It's not a requirement to replace the whole gas line if there is a leak.
First thing to do is try and locate the leak - if possible.
If you can, easily, then a repair could be done at that point and if the gas line holds pressure, it's OK to use the existing service
Where abouts in Vic are you located?
Reply to Upgrade gas supply line from galvenised steel to copper? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
