Discuss vailant boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eddiebrown424
Hi All,
If I isolated a boiler (combi) and opened the cold feed how much water approx should I expect to drain. Its a vaillant its a turbomax and the customer has no water comming out the hot tap.
Thanks in advance
Eddie
Sorry
Don't understand the question?
Isolated boiler and opened cold feed?
Sorry
I think he's saying if he isolated the cold supply to the combi then opened a hot tap how much water would come out .
Depends which tap your opening if that's the question
If no water out of hot tap ! then something is blocked in boiler or valve under boiler is closed off what type of filling loop is fitted ? if type with 2 grey taps make sure they are both closed
Reply to vailant boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
