Discuss VAILLANT ECO TEC PLUS 835 in the Central Heating Forum area at PlumbersForums.net
Installed the above boiler today. They quote 14 ltrs per min hot water.
Looking at the heat exchanger, it does not look any different in size to the 832 (well I know, its only 3kw more!), but comparing this to the 838, that heat exchanger is nearly double the size? and the flow rate on that is not that much more 15.9 liars per min? am I missing something?
Reply to VAILLANT ECO TEC PLUS 835 in the Central Heating Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
