Currently reading:
Vaillant Ecofit 30 - Excessive plumage?
Discuss Vaillant Ecofit 30 - Excessive plumage? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Zippymark
Hello, I've had a customer saying their boiler steams a lot, which I explained was normal, and will be more noticeable in cold weather, but when I saw it it did look a bit much. What do you think?
Short of a leaky heat exchanger I can't think what could cause it either. Boiler is 1 year old.
8hS3ADAzYAfe2wMc8
nePthPBgbX5PeHkj7
Looks ok to me on hot water
Fair enough, and it was probably close to 0°C when that was taken. It did half fill the garden with plumage, maybe the air is pretty still there. I might just recommend a plume deflector/plume kit.
Looks ok to me? I would say a plume kit would be advisable, as it close to the door, it’s always going to be blowing right where they can see it/as they open the door. After all a plume kit is there to stop nuisance plume....
But you could try the Vaillant route if you/your customer are concerned
Reply to Vaillant Ecofit 30 - Excessive plumage? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
