Discuss Vaillant EcoFIT pure leaking water from behind condensation trap in the Central Heating Forum area at PlumbersForums.net
I have a Vaillant ecoFit pure 830 which developed the f.22 fault, the pressure had dropped to 0.2 bar, i refilled the system and away it went, i noticed yesterday that there was water on the floor below the boiler and noticed that water was leaking from a small hole located behind the condensation trap. This leak is lowering the pressure but i don't know and can't find anything on what is causing it.
Does anyone know what might be causing the issue and how might it be fixed?
Thanks in advance
Best to call a heating engineer out could be something simple like and air vent or might need a part etc
Reply to Vaillant EcoFIT pure leaking water from behind condensation trap in the Central Heating Forum area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
PSxxxxxx
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
