Discuss Vaillant Ecotec plus 428 No heating in the Central Heating Forum area at PlumbersForums.net
Hi
We've got a Vaillant ecotec plus 428 that doesn't seem to want to supply any heat to the radiators despite the hot water working just fine.
Of some importance (I think) is that there is no radiator symbol displayed on the boiler screen, only a tap.
We have a wireless thermostat (Altech ALTHC015) with fresh batteries calling for heat connected to a box displaying a red and green light which I believe means power and connectivity are fine.
I have so far tried turning everything off including the Honeywell ST9400C controller and removing the batteries to reset anything that might be causing a bug as last year it turned out the wireless thermostat had just bugged and resetting it worked fine.
The boiler displays s30, indicating no call for heat. Manually firing the boiler does not make the radiator symbol appear and they don't get warm.
Any advice would be greatly appreciated.
Warmest regards, Matt
Is there an override on the thermostat? Try this. Could be a faulty motorised valve, or could be the thermostat. Do you have any test gear?
Thanks for your reply. There doesn't appear to be anything on the Altech unit to override; on the Honeywell controller there is an override button and I can set it to run continuously (If that's what "Cont" means in this context) but no luck on either. What would you define as test gear?
If the receiver green light is on, that shows the communication is working.
Do you know what is happening with the motorised valve(s)?
You appreciate (I believe for your system) the Altech controls the motorised valve, and within the motorised valve is the switch that calls for heat from the boiler. If the valve is not moving that switch won't be operating.
Thanks for your replies. I've looked into the motorised valves and I've found two of them. Both can be moved using the manual bit on the back fully over to one side and back again. Should there be anything outwardly obvious happening with the valve when it is operating?
I have a multimeter so I can test things if required.
The controller appears to be connecting to the boiler just fine as the boiler displays when the pump is running.
Whilst I am here I have another question to add. We have always had, since we moved here, an issue with the boiler constantly cycling e.g. rapidly heating up to 70 degrees within several seconds and then shutting down with a flashing radiator symbol for a few minutes before firing again; is this anything I can change? I've got it on video, if anyone wants to take a look I'll upload it.
Need to link out the heating thermostat
On the reciever need to check if it’s outputting live / call to the system as it could be just the room stat is dead
Reply to Vaillant Ecotec plus 428 No heating in the Central Heating Forum area at PlumbersForums.net
I have a Vaillant Ecotec Plus combi boiler that was installed just over 6 years ago. It has been serviced annually, the most recent service being...
3K
I recently had a new 2023 Vaillant ecoTec plus 630 (30kW) system boiler installed along with a Low Loss Header (LLH) in my house. I have 21 rads...
Hello everyone, I'm facing an issue with my Vaillant EcoTec 832 boiler and would greatly appreciate your expert advice. The Problem: Heating...
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating...
