Discuss Vaillant F54 & F28 fault code help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
billski
Anyone had any experience with F54 & F28 fault code on a Vaillant Eco tec plus 831?
It locks out but if you leave it for a while, sometimes days, it fires back up. Fiddled about with the wiring harness and it seemed to sort it for a while, but not sure if that was coincidents. I'm guessing it can only be the gas valve or power to it.. board was replaced about a year ago so hoping it's not that.
F28 is usually a lack of gas, but can be the condense pipe blocked, an issue with the flue, spark electrodes, spark lead, and a few others. F54 - a new one on me, you sure that she the correct code?
Have a look at the status eg where it gets upto
I’ve just fixed one the pressure sensor was blocked (electronic) so it wasn’t sensing the pump was running nice easy one for a change
Reply to Vaillant F54 & F28 fault code help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I've got a testo 327-1 that I purchased back in 2019 when I went self employed. The analyser hasn't been calibrated since purchase. After...
