Discuss Vaillant g10 seals and servicing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can’t be any worse than the pathetic eu beaurocracy we find ourselves in now
So far until that comment before being provoked by someone I wasn’t rude. The only person that’s provoked anyone was you
Ron, we are going in circles with this. Your comment, YOUR comment!!! ruffled a lot of people. You are not the god of boiler services, you don’t get to dictate to people on here who is doing it right and wrong. You have to be man enough to stand by the following fallout because of what you said. You cannot toss around the racism card because people criticise a boiler which lets be fair originated in Germany. We’d have the same digs at Italy for ferolli and Biasi. What you fail to see or don’t want to see is that you are wrong with that very early sweeping statement saying most of us don’t service properly
And...... you also made a discreet violent comment towards myself ! Which I’m sure I interpreted correctly.
Just remember, you don’t know what’s on the tuther end of the touchpad, when making threats.;)
now now no need for that either was it
Junior mk2 ?
Common stock in most places city plumbing if there still open have them
:D
Yes mate sent it in the post. But now the heat ex is brand new the CO reading is blooming high.
Oil in the manufacturering normally go back in a week to do the readings / paperwork
That is the damn reason why the boilers don’t last long. When I service a boiler I strip it down, clean burner, flush main heat exchanger, siphon, ****, replacing seals, electrodes . that’s what the customer is paying for. There is no other service than that. Majority of engineers don’t service boilers properly and that’s so wrong.
@Riley, where did I mentioned that the engineers on here don’t service properly? I said in general not particular the engineers on here did I?
However, if you say I’m wrong that’s fine with me don’t bother me at all, I will keep it going the way it should be.
I realise English is not your first language Ron but you have to be mindful of people reading your messages. Text speak which is what this essentially is, can be construed in many ways depending on who reads it. And you can see from the reaction how many people got upset by it.
View attachment 37958 thought I would continue this here instead of the other thread
When I went in the Ecotec training day a few years ago I was told to open the heat exchanger up every 5 years unless FGA reading say otherwise
Every time you open the heat exchanger you should replace the seal
Am I wrong? Or has it changed?
Just been on a Vaillant course. They say that the seal only needs changing if you inspect inside the burner chamber which should be done every 5 years as a minimum. He said that you can change annually if you wish, but there is no need.
Does that mean your vai
Reply to Vaillant g10 seals and servicing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant Ecotec Plus combi boiler that was installed just over 6 years ago. It has been serviced annually, the most recent service being...
3K
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Dear forum, I've an open (gravity) CH system supplying radiators only (AGA does the HW separately). It's a Vaillant Ecotec 435 installed 2018...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially...
First post as I can not figure this one out. I have a hot water boiler heating system, gas fired, with an HTP SuperStor indirect hot water tank...
