Discuss vaillant/glowworm gasket seal is there any difference, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
roomheating
i have 10 seals part number 801635, the new ones, i thought you could use these in vaillant boilers or not ? thank you
they are identical but if your selling them i would get permission from admin first,secondly they may be the same but no one will touch them if the part numbers dont tie up
Was just to fit on my own jobs as used to for sse, and i thought they was but they have diff numbers and could not remember thank you
Reply to vaillant/glowworm gasket seal is there any difference, in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do you recognise this shower drain rubber seal? I have searched the web and common plumbing spares suppliers but I cannot find which it is. It...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig...
Hi everyone, I have taken out the heat exchanger because a tiny leak was found around the red gasket at the top of the heat exchanger of a...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no...
C
Hello, I have 22 year old water tank boiler in a rented house. While the burner was lit yesterday I smelt a very faint smell of gas. It was...
