Discuss Vaillant heat only Home regular 18. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
Pretty new boiler this guys , went to service it earlier today , service got abandoned because the bleeding thing would not go in to high fire , rang Vaillant, no joy , emailed them , no reply yet , anybody know how to do it , cheers in advance .
Sounds same as a glowworm energy with the mode button...so do you have to get it to P1 then you can set it from 0 to 100...100 being high fire?
Yep I know what you mean , but whatever I press in whatever order it still wont go .
Hopefully if Vaillant get back to me they will help.
I will post on here , when and if I find out .
I just think theres a nack .
Yes need to upload them to utube / others then post the link same as any other vid
Only pics from your phone / computer
Looking at the instructions mate. It looks like you use p1 the bump it up to 100
1. Ensure that the gas inlet working pressure can be obtained with all other gas appliances in the property working. 2. Close the gas isolator cock (1). 3. Undo the sealing screw on the measuring nipple (2). 4. Connect a pressure gauge to the measuring nipple (2). 5. Open the gas isolator cock (1). 6. Start up the product with check programme P.01 (system with eBUS controller) or P.03 (system without eBUS controller). 7. In addition, ensure that maximum heat can be dissipated into the heating system by turning up the room thermostat. 8. With the boiler operating at full load check that the gas inlet working pressure at the reference test point (2)
Booooo. That is rubbish. @Dan @Lou surely you can fix this. I do not have a YouTube or Dropbox account and don’t really want one. But want to upload a video here.:mad:
send it me i will sort it if thats ok
Reply to Vaillant heat only Home regular 18. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
