Discuss Vaillant spacer frame in the Plumbing Jobs | The Job-board area at PlumbersForums.net
novicegas
Hi, anyone fitted the spacer frame to a Vaillant, am considering it for a system to combi swap, is it relatively easy? Can't seem to find any info on it anywhere, cheers
Fantastic jigs loads of room behind for clips and stand offs using them every week at the moment screw bracket to wall build frame and hang and fix. makes jobs with pipe work above so much easier.
If you get caught out and havnt got the spacer frame the same effect can be achieved by using 2 x 2 and plywood
I've used one and it was pretty decent, though i couldn't help thinking you could knock something up as suggested above for a lot less money.
Space frames imo always make the boiler look like a washing machine screwed to the wall if it is in a kitchen or somewhere where it looks totally out of place.
Consider a worcester. You can pipe them up behind without kits.
Reply to Vaillant spacer frame in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Good morning, I have a hinged shower screen for my bath that I don't have fixings for. The guide holes in the screen line up with guide holes in...
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not...
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi, all. I have a leak problem behind the washing machine. It's a pipe that is leaking directly into a drain. It used to drip but now is leaking a...
Pritesh Patel
I have a Vaillant ecoFit pure 830 which developed the f.22 fault, the pressure had dropped to 0.2 bar, i refilled the system and away it went, i...
2K
