Discuss Vaillant Turbomax noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Went to do a gas safety check on a Turbomax today
It’s fine in CH
Makes this groaning noise in HW if the temp dial is above half way.
Diverter?
Doesn’t seem to have a bypass
needs to be utube mate then upload the link dans working on direct upload but not ready yet
sorry its late
Are you referring to the band saw noise? Is the noise coming from the combustion chamber?
If so could be pump or fan. Try oiling the fan see if it makes a difference get it and replace it.
It’s fine in heating and HW if the temp dial is below half.
Only happens if the HW temp is turned up
I had exactly the same problem with a TURBOMAX PLUS 824 E. It made the noise only when the burn modulated up to full. Could not trace it to any particular component because the whole boiler vibrated. Fitted a new primary heat exchanger and solved it. Fairly easy to fit. No visible fault on old heat exchanger.
Reply to Vaillant Turbomax noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
