Discuss Vaillant v-smart stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Not yet mate. Got one lined up hopefully in the next few weeks. May go back to the Honeywell t4r Though. I have been fitting 350f or timeswitch 150 and Vaillant stat
They look easy enough though. Just make sure the switch cables are at the ebus connector.
I fitted a couple recently Vsmart. Pretty easy ... the only thing you have to make sure is that the customer has got WiFi and an access to his phone to set that all up
Pros will be 7 years as standard through advance.
Plus will have 10 if you fit the Vaillant filter
It fit what you like and pay to extend
I'm fitting an 835 with vsmart on Friday
First Vaillant for a while
do i see a pattern ron last week it was spirotech this week its flamco :D
Pattern?
I am fitting Spiro for long time but they are not combined. They are very good and reliable but Flamco has a combined filter and micro bubble. So, why installing 2 things than 1 which has it is combined? Reducing the risk of leaks. I just get always updated with good reliable stuff that’s the reason why I point things out for others. Perhaps, one or another is interested in some newer products. Didn’t know would be wrong
ÂŁ98 plus vat for the spiro comb with mag
Update:
The V-smart was simple to fit.
The 835 combi is a nice boiler, just the MIs are a bit poor
Reply to Vaillant v-smart stat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
