Discuss Valiant 831 Boiler - Wiring of thermostats and motorised valves?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Chrismw1989
Sorry in advance for the long thread! Just want to make sure i provided as much detail as possible.
We are currently building an extension and whilst devastating the house have decided to install a new boiler, we have also opted for a John Guest UFH system to be installed in the new extension.
I installed the boiler and rerouted the pipe work (we previously had a boiler and tank upstairs) over the weekend and then had a qualified plumber connect the gas and commission the boiler yesterday.
I was also expecting him to complete the wiring of the motorised valves and stats however he seemed to lack knowledge on how these should be connected and just wired so that the boiler worked until an electrician had a look. Im not convinced its right!
At the moment we have no control over the heating and I would like some advice on how to connect up the devices.
Overview of system
Boiler - Valiant Ecotec Plus 831 combi
Heating zones -
1 zone for radiators
1 zone for UFH system
The Heating flow from boiler is connected to 2, two way motorised Honeywell valves. 1 valve serves the radiator heating zone, and the other valve serves the UFH manifold.
I have been advised that we require 2 independent programmers/thermostats for each zone.
For Zone 1 (Radiators) I have currently used the stat from the previous boiler as it was only few months old. This is a Horstmann Centaurstat 7 which is a 7day, single zone programmer allowing 3 programmes per day.
For zone 2 I have purchased a new JG 12v Programmable 7day thermostat.
I therefore have 2 programmers/stats and 2 motorised valves. One for each heating zone.
The UFH manifold pump has an automatic temperature sensor to shut off its pump when the motorised valve is closed.
The plumber has currently wired all 4 devices into a central wiring box including a feed to the boiler.
I would be extremely grateful if someone could help me on how the various devices should be wired into the connector block/ boiler.
The only control we currently have is to physically turn the boiler on and off if we want the heating, neither thermostat or programme seem to control the boiler!
Not ideal waking up in the morning to a cold house and having to manually turn the boiler on!!
Thanks for your help in advance, please let me know if I need to provide any extra details!
I have some pictures of the installation that i would like to upload, but my permissions don't seem to allow it currently??
Chris
Definitely the safer option Chris. So many different wiring options with these better to get it right first time
Why not to get someone in who knows what they are doing, Chris!?
I am a fairly competent DIYer and happy to wire in the thermostat, just looking for some advice on how to connect them all up.
Will also be quicker than getting someone around as i can work on it in the evenings rather than waiting until the weekend to get someone around.
Echo the others; you'd be much better off getting yourself a decent engineer in to wire it up. It wouldn't take them too long and i'm sure it wouldn't cost much.
Note I said engineer, as in heating engineer. Definitely don't get an electrician to do it!
Reply to Valiant 831 Boiler - Wiring of thermostats and motorised valves?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
