Discuss Valiant ecotec pro base thermostat broken in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi pictures say it all really..
The knob to turn to adjust the temp of heating,(and hot water) just free wheels, and pulls off.
Can I just stick a screw driver or something in and twist?
Is there a way to work out what it's set at?
Is there an easy perm fix?
Easy perm fix is to get a gas safe engineer in to replace the knob. As they will have to remove the cover to fit a new one
Using a pair of pin nosed pliers just wriggle the shaft. The temperature will be displayed in the window. Adjust as required.
how much to sort this job? i can see you can replacement knob for about £10. should i attempt? how much for a engineer to do is a fair price? greenwich
Hours labour and a coffee. We don’t talk prices on here
You won’t know without a gas safe engineer as you can’t take off the cover legally I’m afraid
please don’t poke a screwdriver through, the plastic insert goes into a live connection.
Closed
Reply to Valiant ecotec pro base thermostat broken in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Looking for some advice on a new Valiant Ecotec Plus 615 boiler, fitted a few weeks ago. It makes an on/off vibration shown in the video...
3K
I’ve got a vantage concealed cistern that had an intermittent problem a couple of years ago whereby the flush wouldn’t shut off and it...
2K
Hello all. I'm looking for advice to help my heating engineer fix my problem! He actually installed the unit. It’s a 3 year old oil boiler, a...
5K
5K
