Discuss Valliant ecofit sustain 618 elastic banging noise in the Central Heating Forum area at PlumbersForums.net
M
Marty_2015
Hi All
New here I've got a problem with our brand new ecofit sustain 618 boiler about 6 months old and seems to have developed a banging noise. Below is a link to a youtube video so you can see what it sounds like. I've had the plumbers around and they can't work out what it is its driving us insane.
It sounds like an elastic banging on metal and when the plumber took off the case seems to be coming from the top right hand side of the boiler and seems to happen after the boiler has been heating up the hot water/heating for a while and is cooling down. Seems like its some sort of contraction thats causing it. We've checked all around the boiler and its definitely not coming from any of the pipes.
Sorry the video is only from underneath the boiler however even with the front off nothing obvious looks out of place.
Any help would be much appreciated!
Have you called vaillant out as it’s under warranty?
And what did they say ?
Normally on the hex to mount it to the case glad it’s sorted
Reply to Valliant ecofit sustain 618 elastic banging noise in the Central Heating Forum area at PlumbersForums.net
