Discuss Velux solar panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
justlead1
I have a zinc roof to install. Velux panels are to be fitted, which require me to flash around. However its not clear with the information i have to determine whether the flow and returns from the panels pass through the roof with in the area of panel or adjacent to panels. Has any one experiance with these units?
If there intergrated in roof then flow and return will be under solar panel flashing
Justlead we are in the process of fitting this week , I will try and look tomorrow . Instructions are rubbish !!!! They also tell you not to follow the video on the website !!!
Thanks for the info. Although i will not be doing this job until January. I might well make a video of the panel installation (a plumber pal of mine is installing this) and post it on You Tube. What do you think?
I will be on the roof tomorrow afternoon and will get some info for you .
I would not video the Velux ones I am not impressed with the kit.
Its as Gray said the connections are all at the bottom of the panels and under the supplied flashing. If you are having 2 panels you get achoice of distances the panels are apart and again the connections are at the bottom under the flashing
Reply to Velux solar panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
