Discuss Vented hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
What sort of pressure do you get from the average vented hot water system?
Got a few kitchen taps to change and grohe only go down to o.5
How high is the tank from the cylinder ?
Normally 0.1-0.4 bar
How high is the cold water storage tank (that feeds the hot water cylinder) above the draw off point?
Measure ( height), it in meters and that will give you a close enough idea of pressure.
e.g. If it was 6 meters, you would have 0.6 bar, if it was 8 meters, you would have 0.8 bar. and so on.
Reply to Vented hot water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone remember the Mira mixer shower that would work down to a really low pressure on a vented hot water system without a shower pump?
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
