Discuss Viessman 4 pipe setup with zoning using OT in the USA area at PlumbersForums.net
I’m in the process of looking into the Viessman 4 pipe system to use with the Heatrae Sadia Megaflo and the Vitodens 100W system boiler I have.
Currently, I have two Nests zoned for upstairs and downstairs, would I be able to use multi zone with the 4 pipe setup - would I then be able to use OpenTherm using this configuation?
I would like to the the ability to use the weather compensation with the system boiler too.
I take I would need the following:
Weather Compensating Kit (DHW Cylinder Demand Terminal Box Included)
DHW Cylinder Sensor Unvented
Questions?
Would I be able to make use of OpenTherm using two nest thermostats?
Would I need to use Viessman controllers + programmer?
Is multi zoning possible with the 4 pipe system?
As always, thanks in advance.
Reply to Viessman 4 pipe setup with zoning using OT in the USA area at PlumbersForums.net
