Discuss Viessmann multiple zones in the Plumbing Zone area at PlumbersForums.net
I know that through opentherm thermostats it is possible to control Vitodense 100-w DHW. But in case you use a simple thermostat there is no way to turn it off remotely.
In case of having multiple zones I can't find a way to control dhw since only one opentherm thermostat can be connected.
Is there a way to be able to control DHW and multiple zones at the same time?
Hot water prioritie box also sounds like a weather comp sensor would be best and just use standard thermostats inside
Have you phoned Viessmann to get there thoughts ?
@townfanjon
Reply to Viessmann multiple zones in the Plumbing Zone area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
