Discuss vokera compact 29he: DHW ok/ CH cuts out after 10mins??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
johno_uk
After any advise, been to look at vokera compact 29HE fault. No MI present. Hot water is ok and heating works fine for about 10mins, then boiler goes back into stanby. No lockout or red/amber led. Green light flashes faster. You can then turn off/on and will repeat the cycle. On first look, everything looked ok: Flue, APS, thermostat. Spoke to Vokera tech line, who reckons it has to be dirty venturi or gas valve. Cleaned out the venturi and replaced the gas valve (was stuck on min burner pressure) and set to correct min/max burner pressures. Problem still exists.
Anyone any ideas or had similar fault? Thanks in advance
that was my first suspition too, but appeared to be ok, will double check again tomorrow.
Cheers for your reply
Hi did you find he problem here? My Compact HE 29 has started doing this, hot water is fine. Turn on the heating and it fires up and stays on between 10-20 seconds and then goes back stand by and flashes green, turn hot water on and it fires up no bother and get hot water just no central heating...
Reply to vokera compact 29he: DHW ok/ CH cuts out after 10mins??? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hi all, For my boiler worcester bosch greenstar 30Kw Ri Compact, I noticed that, within programmer set time, for heating, if the house...
Hello ! I have recently moved into a new house – or rather a 1960s built house. The central heating system looks to be around 10-12 years old...
4K
Good morning, I recently had an extension, new bathroom and new en-suite fitted. Prior to the works the hot water worked. Now we have moved...
3K
Hi! I have a 9 year old Baxi combi boiler. When I turn the central heating on, the boiler pressure is getting so high that it keeps cutting out...
1K
