C
craig2050
Wondering if any of you guys could help My Vokera boiler is about 7 years old and for the last 6 months its been a bit of a pain It started when my radiators got hot when i only had the hot water on Changed the diverter motor and all worked fine for a while then code 07 came on and the psi pressure gauge dropped re-pressurised to 1.5 bar and it only lasted 1-2 days before it happened again So i changed the primary DHW thermistor. I thought problem solved Not Still only lasting 1-2 days ( No leaks ) the only water i seem to be losing is a few drops outside from the safety overflow HELP
Thanks in advance...
