Discuss Vokera Linea24 Hot water issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Alexander MIlton
Hi all,
So i went away for a couple of days and turned off the boiler as you do. When I've come back and turned it back on I've had a host of problems that haven't happened before.
- No hot water, only lukewarm/cold water.
- When downstairs hot water tap is on no water from upstairs tap.
- Even though thermostat is set to off, centeral heating is on.
The boiler itself is a Vokera linea 24 and it was definetely all working fine before. The only thing that i have ever had was a few months back it lost all pressure and had to be filled back up.
The boiler LED is green, the temperature says 61 on it as well.
Not sure whats going on, tried a few things like turning it off for a hour and leaving it for a few hours but no luck.
Hoping someone could recommend something before getting a plumber out?
Cheers
Alex
sorry to say you've tried all the basic things, and you have pressure in the boiler (1-1.5 bar cold 2-2.5 bar hot)
time to get a gas safe engy out im sorry to say
You need a engineer to have a look does the heating pipework get hot when you try and run hot water?
Reply to Vokera Linea24 Hot water issues. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
